• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Mentor
    Railing and Glass Baluster
    389 Views, 1 Replies
    02-09-2012 04:57 AM
    I have this railing with glass baluster.  The glass baluster panel is 2'-0" in length.  The railing is not on a 2'-0" modular length so the last panel extends past the corner of the railing.  I can set the baluster placement to be centered on the railing which gives me a panel at each end that is extended past the corner.  I understand this is normal based on my what I am asking Revit to.  My question is, how can I get the 24" glass panels centered on the railing length but have the two end panels automatically adjust in lenght to make up the difference and not be 2'-0"?  Thank you.
    Product Support
    Chris.Aquino
    Re: Railing and Glass Baluster
    02-10-2012 03:47 PM in reply to: mbuonocore
    I would use a curtain wall as a railing to better control the panels. The following blog post has more information:
    Curtain Walls as Railings
    Chris Aquino
    Revit Support Specialist
    The Revit Clinic
    @Revitclinic
