• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    RVT Update error messege
    100 Views, 1 Replies
    01-18-2013 05:56 PM
    i just download the revit update and when is open it its give me these messege
    what is that messege mean ? can any body help !
    Please use plain text.
    Employee
    Re: RVT Update error messege
    01-22-2013 07:33 AM in reply to: weak90
    This message indicates that you do not have the correct update for your installed version of Revit.  There are two items that will determine which update is required for your installation.  The first is whether or not you have the 64-bit or 32-bit version of Revit.  Next, you have to download the correct update for your installed version of Revit.  Here is a list of the different Revit versions, each of which has updates specific to them:
    Autodesk Revit
    Autodesk Revit MEP
    Autodesk Revit Structure
    Once you get the correct version of the update, you should be able to install it without problems.
    Tony Michniewicz
    Autodesk Revit QA
