• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    REVIT 2013 - edit boundary, finish sketch buttons missing
    1212 Views, 1 Replies
    11-06-2012 08:59 PM
    I am encountering issues with the "edit boundary" tab on the ribbon, as well as "finish sketch" when the edit boundary tab DOES show up.  i don't know how to finish the sketch without this, so i have to undo everything.  i have seen other posts related to this issue, but none of the solutions resolved anything for me.  does anyone have a suggestion or solution on how to fix this?
    thanks.
    Please use plain text.
    *Expert Elite*
    Re: REVIT 2013 - edit boundary, finish sketch buttons missing
    11-07-2012 05:44 AM in reply to: swyoung10
    We have also run into this, and I have found a few workarounds.
    1. Try hitting the black Save button -- this will sometimes return the ribbon back to normal.
    2. Check the version of .NET your computer is running--if you are using Revit 2012 and have a version of .NET higher than 4.0, it will cause ribbon problems.
    3. Use a keyboard shortcut such as FS (Finish Sketch), FG (Finish Group), etc.
    4. Try unchecking all the boxes in View>User Interface, then re-check them.
    If you are using Revit 2013, be sure to install Update 2, as it has apparently fixed the ribbon problem.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
