• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Question about unintended changing scales in other sheets
    210 Views, 4 Replies
    09-02-2012 02:12 PM
    I have a floor plan with a very long footprint in a "View" drawn at a convenient scale.
    The long building had to be broken to be put on several different "Sheets", and each of the floor plans on each of the sheet has a scale.
    When I change the scale of the partial plan on one "Sheet", all the other sheets also change to the same scale and also the original view changes to the new scale.
    Is there a way to assign the desired scale of the plan on one sheet without affecting the scale on the other sheets and on the original drawing view?
    Thanks in advance.
    Please use plain text.
    LisaDrago
    Re: Question about unintended changing scales in other sheets
    09-04-2012 05:33 AM in reply to: octavio2
    It sounds like you have your views set up as dependent views creating the parent child relationship. With that - what ever happens in one view happens in all dependent and parent views.
    The only way to break this is to make them all independent views, I have attached an image of how to do it.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    09-08-2012 02:53 PM in reply to: octavio2
    Thanks for the suggestion, I followed it as I state below:
    I was working only with a primary view at a determined scale, so to make independent views I had to create two new dependent views from the original primary view of the building floor plan, and then from one of these I created the independent view with half the building and I put it on a new sheet at the desired different scale.  I notice then that the primary view do not change scale by doing that, so that was good.
    But in the new sheet with the new independent view the original tags that I originally created in the primary view  disappeared and are missing and I could not put them back (so far) with the visibility graphics.  I notice that I can put them back creating new tags (i.e..., the bad thins is that I had to place each one individually again, but the good thing is that the new placed tags inherited the old room names and numbers, so at least that two way correspondence was good).
    My next questions:  In situations like that, is there not a quicker way for the original tags to appear in the new independent sheet and view at the correct new scale without having to go thru the additional steps of placing each individually again?
    Thanks in advance.
    LisaDrago
    09-08-2012 03:09 PM in reply to: octavio2
    Tags are considered annotation - therefore it is view specific, what view you place it in - is the ONLY view you will see it.
    There is a Tag All Not Tagged command on the Annotation tab>Tag pallet. This will give you the option to tag all of the rooms at one time. In the dialog box - you just have to select what you want to tag and click apply and it will place a tag in every room - this is the quickest way to do that.
    Image attached
    And yes - it remember what room it is. That makes it very convenient when you need to do a section or another view you can quickly drop a tag in and it will always be coordinate.
    LD
    09-09-2012 03:30 AM in reply to: octavio2
    Thanks, Lisa.
