• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    snydersp
    Problems running Revit with seemingly great PC specs
    135 Views, 2 Replies
    02-08-2012 02:02 PM
    When I run Revit on my computer it is very laggy and slow, and it freezes up when I try to do basic things like drawing gridlines. I am running an i7 processor, have 8 gigs of RAM, and an nVidia GEForce graphics card.
    2 things: My hard drive runs at 5400 rpm (not sure if that matters) and I see that the GEForce is not tested for Revit.
    I also see that my RAM use is at 86% when I run Revit.
    Any suggestions? I don't know how to resolve this.
    New Member
    lighting_guy
    Re: Problems running Revit with seemingly great PC specs
    02-08-2012 03:50 PM in reply to: snydersp
    While you're waiting for a more informed reply I will can offer the following thoughts:
    1. You might want to post this question to a different discussion group as this isn't really a Revit question and you might find nerdier (hardware) types in another area.
    2. Your issue is clearly not related to your proecessor or RAM. I run revit on an i5 laptop with 4 gigs of ram and don't have a problem other than my graphic card crashes on occision.
    3. 5400 rpm hard drive is a bit slow and will definitely have an impact, but how much is hard to say.
    4. You don't mention your graphic card spec beyond the fact that it's a GEForce card. There are many, so you might want to be more specific.
    5. You also don't mention your OS. If you're running an i7 processor you probably have Windows 7 home premium or better, but certainly if you're running an older OS that could also be an issue.
    6. You might want to start by doing something as simple as cleaning up your hard drive to see is that improves your performance. You may have some sort of spy ware or virus running in the back ground. When I run revit and autocad simultanesously on my laptop I never use more than 3.5 to3.75 gigs of ram.
    Good luck
    SG
    Member
    snydersp
    02-08-2012 09:12 PM in reply to: snydersp
    Thanks so much, will make corrections and post to the proper forum!
