• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    arya2013
    Problem with curved wall of the shell
    225 Views, 2 Replies
    08-21-2012 11:49 PM
    Hi
    I have a problem with a picture that I've attached here.
    I made the curved wall and the wall directly into the shell and got out of it was drawn.
    How do I delete these extra parts.
    Thank you, I have answered.
    Perhaps the problem is that many people work with Revit.
    Please use plain text.
    Alfredo_Medina
    Re: Problem with curved wall of the shell
    08-22-2012 12:44 PM in reply to: arya2013
    Using the same curve that generated the curvy wall, create a void, and cut the straight wall with that void.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Contributor
    arya2013
    08-23-2012 01:13 AM in reply to: Alfredo_Medina
    Hi
      Thank you for your answer.
    I do it but I do not exact
    Because of the low wall above the curve moves.
    Please if you can further explain or movies and photos can be provided.
    Ariyani
