• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Problem when using lines with thickness
    79 Views, 1 Replies
    04-28-2004 04:59 AM
    I need a dashed line with thickness to indicate fire classification, the problem is that every dash gets rounded end caps. I want every dash to have straight end caps. Does anyone have a solution to this problem?
    Regards
    Helge Mjos
    Please use plain text.
    *Aaron Rumple
    Re: Problem when using lines with thickness
    04-28-2004 05:56 AM in reply to: Pelge
    Yes. And a very good one. Use the repeating detail feature. With this you can make lines of just about any type that you can imagine. "Pelge" wrote in message news:31006157.1083153613041.JavaMail.jive@jiveforum1.autodesk.com... > I need a dashed line with thickness to indicate fire classification, the problem is that every dash gets rounded end caps. I want every dash to have straight end caps. Does anyone have a solution to this problem? > > Regards > Helge Mjos
