• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    t_deferme
    Problem: visibility of a beam in plan view
    252 Views, 1 Replies
    07-15-2011 02:08 AM
    If i draw a beam in plan view en define the height, the beam disepare. Is there a posibility that the beam is in place and you can see a dash dot line and two dashed lines in plan view?
    thx
    Please use plain text.
    Re: Problem: visibility of a beam in plan view
    07-17-2011 02:18 PM in reply to: t_deferme
    Most likely the beam level is above the view cut plane level. If you put in a plan region where the beam is located ( View tab / plan views / plan region ) and set this cut level to be through the beam, you can then see the beam.  You can then use the linework tool to get a dash dot line or however you would like it to display.
