• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Expert Elite*
    LisaDrago
    Re: Printing to PDF problem
    05-18-2012 11:24 AM in reply to: bward
    Bluebeam is an awesome PDF maker and I have never had problems using it with revit - and it even creates 3D pdf!
    Check it out here...
    http://www.kalblue.com/Software/bluebeam
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Please use plain text.
    New Member
    06-16-2012 08:33 AM in reply to: LisaDrago
    I'm having the same issue. One PDF printing 40 or more times if I have 40 or more drawings.
    Using Revit 2013, Windows 7 64. I had the same issue with previous Revit versions. Also, I am using latest version of Acrobat Pro will all updates.
    New Member
    10-26-2012 04:57 PM in reply to: bill
    Yes, it is very frustrating .. just spent the last 45 min cancelling each print range plot attempt (38 sheets).  The first print range of 38 sheets came out as wanted in one combined pdf.  Then, the Save PDF As dialog box came up 37 more times and even if you hit cancel, it runs through the motions of printing out the selected print range.
    The only reason I didn't kill Revit in the Task Manager was because I had a different local file open that I hadn't synced in a while.
    Please fix.  This has happened multiple times
    Using Revit 2012, using Windows 7 64, and Acrobat 8 Standard.
    John
    Active Contributor
    awes
    10-28-2012 01:47 AM in reply to: LisaDrago
    99% same problem as jcastro starting with rst 2009. Set of 1-8 sheets runs without problem, with 9 or more print session starts repeating itself without possibility to cancel session, instead you have to cancel separately each sheet.
    Workaround is to print sets of 8 and combine them.
    rst 2013, win7pro, acrobat 8 pro.
    JamaL9722060
    10-28-2012 04:10 PM in reply to: awes
    the issue in my case that my Revit doesn't print pdf file at all!
    i have Revit 2012, Acrobat 8.0 Pro.
    what might be the problem?
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    10-29-2012 06:53 AM in reply to: bward
    I have encountered the issue in which Revit will print to PDF and want to create numerous files in an unbreakable scripted action, even though the setup is set to "Combine multiple selected view/sheets into a single file".
    I have found that this is caused if the last place that the user clicked was in the Project Browser or if the current View is non-printable (i.e. a Schedule View). Prior to printing, be sure that you open any printable View and click anywhere inside that View to make it the 'active window'. Following this procedure, I have never had this problem again!
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Contributor
    awes
    11-05-2012 05:24 AM in reply to: CADastrophe
    Your 'workaround' seems to work. I just succeeded to print 30 pages into one pdf file by having a printable view as active window. Thanks! The neverending printing is somehow related to rvt - I've had the same issue with both acrobat 8 and pdf-exchange &rvt but not not combined with other cad or office programs. In my opinion there's something to be fixed.
    New Member
    02-07-2013 02:46 AM in reply to: bward
    Thanks for the solution! It worked for me too!
    If you encounter the problem (win 7 64) of having a printing loop, and haven't saved your file yet, you can also open task manager --> services --> terminate Spooler. In this case you just need to quickly click away the messages revit gives you, but that goes a lot faster than waiting for all the pdf's to be printed.
    JamaL9722060
    03-08-2013 01:19 PM in reply to: CADastrophe
    Thank you very much Corey for the very informative answer. This introduces a root solution for such stressful problem. With your help, now I could print all my sheets in one pdf file
    All the best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    New Member
    03-27-2013 03:33 AM in reply to: bward
    Thank you for the work around, I have had this problem several times.
    I dont understand why Autodesk dont fix the bug, its seems that it is a old problem.
