• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    d.nijsink
    Printing linked cad files
    169 Views, 2 Replies
    02-06-2012 07:51 AM
    My project has some Linked CAD-files (drawn in layer Foreground). E.g. a bed (lines and solid-hatches).
    Above this I have added a Detail Item with measurement (set to front).
    1. When I print my project as Vector Processing I get a result as in attachment 'VectorPrint': Lines of the Linked CAD are above the text of the measurement, but the solid-hatches are below the text "4050".
    2. When I print my project as Raster Processing I get a result as in attachment 'RasterPrint': Lines of the Linked CAD are under the text of the measurement. This is what I want. But when I print with Raster Processing, the image is worse than with Raster Processing: more spotty like JPEG-files.
    How to get the image-quality of Vector Processing and the draw-order of Raster Processing?
    (See attachments also.)
    Product Support
    fernanda.firman
    Re: Printing linked cad files
    03-30-2012 05:29 PM in reply to: d.nijsink
    Are you using a pdf creator? Or just printing directly from Revit?
    Fernanda Lima Firman
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    Member
    d.nijsink
    04-02-2012 12:49 AM in reply to: fernanda.firman
    When I print as Vector Processing the result is wrong. When I use Raster Processing the result is as expected, but image-quality is like JPEG, so less good. It doesn't make a difference if I use a pdf creator or a direct print.
