Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Printing in Tabloit or 17 x 11 size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have tried to print in Tabloit or 17 x 11 a Sheet, which of course is reduced, but I keep getting large magins and I cannot get a good print that almost "fit" the 17 x 11 sheet of paper. I have played and changed the settings of both the printer and also of the Revit Plot dialog many times and ahve tried with different numbers and clicked many of the different buttoms in the Revit Plot dialog, but still without success.
This kind of adjustment to "fit" is easy and logical in AutoCAD with the "Fit To Paper" of the Plot Dialog of AutoCAD, but so far seems impossible to achieve in Revit, unless there is a super secret setting there that is not obvious and that I have missed.
What is the way to "Fit To Paper" a Revit Sheet (are the Sheets that we create in Revit 36 x 24?) really well into a Tabloit or 17 x 11 size?
Thanks in advance.
Re: Printing in Tabloit or 17 x 11 size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I haven't found a way to defeat the obnoxiously oversized margins that Revit adds. You're probably best off setting it to Centered and manually calculating the Zoom %, which in your case would be 44%.
⁞|⁞ Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Print your Revit sheets to a full size 24"x36' Adobe file. Print your Adobe file to hard copy with shrink to best fit. It won't be exactly half size unless you start with an ANSI D size sheet. It saves you the trouble trying to set a D size sheet to fit a B size.
Arthur
