• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Printing and previewing a sketch in A4 paper with a scale of 1/100,
    437 Views, 4 Replies
    09-15-2012 12:09 AM
    This is my first experience in Revit.
    What I’m simply looking for is to print the a sketch in A4 page with a scale of 1/100.
    Also, I couldn’t figure out how the print preview works! Sounds to be quite different form what we have in the AutoCAD!
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Re: Printing and previewing a sketch in A4 paper with a scale of 1/100,
    09-17-2012 05:47 AM in reply to: JamaL9722060
    The Print Preview functions pretty much like it does in AutoCAD, except:
    • You cannot use Print Preview in conjunction with the plotting range "Selected views/sheets"
    • "Visible portion of current window" equates to plotting "Display" in AutoCAD
    • There is no Print Window in Revit. (I find this very obnoxious at times)
    • You have two set levels of zoom as opposed to being able to freely zoom in AutoCAD.
    In the images that you posted, under 'Print Setup' your preview is set to "Zoom: 100%" so it is plotting to scale. If you change this to "Fit to page", it would fit better on the sheet. Revit is also determining the "plot extents" based on the outermost elements - namely the elevation symbols in this case.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    09-17-2012 01:22 PM in reply to: CADastrophe
    Many thanks for the contribution and the very useful notes.
    To understand how the print works, I drew a rectangle of 27x29 which could be fit in A4 when we print with a scale of 1/100 (considering that the drawing unit is meter). In case of Autocad, if I need to print this sheet, then I set it as follows:
    What equivalent settings in the Revit might enable me to print my drawing with a scale of 1/100 in A4 pages knowing that the drawing unit is in meter (the 100 cm is drawn as 1 unit)
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    09-17-2012 01:46 PM in reply to: JamaL9722060
    Printing Views can be quite a hassle. So your Print Setup » Paper Placement is currently set to "Offset from corner", which is causing Revit to define the area per the red rectangle in the image below. Setting it to "Center" can also cause a problem if your building is not exactly centered within the extents (almost a certainty) as per the green rectangle in the image below.
    What you will have to do is turn on the Crop Region (a checkbox under the View's Properties) and adjust it to crop out the extraneous annotations that you do not want to print. This will permit Revit to better define the extents in which to print. Plot "Center" for best results, typically.
    If you do not wish to modify your View in this way, then create a Dependent View. That way, you can crop and print as needed without affecting the parent View.
    JamaL9722060
    09-17-2012 02:06 PM in reply to: CADastrophe
    This is quite helpful. Sounds to work.
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
