• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    New Member
    Accepted Solution
    Poor 3-D graphics
    155 Views, 2 Replies
    02-08-2012 01:24 PM
    In 3-D views, materials bleed together and get splotchy.  The red siding, in image below, should not show as gray.
    Working on a Dell M6600 with AMD (ATI) FirePro M8900 Mobility Pro Graphics card on Windows 7 (64-bit).  Was told this system is approved by Autodesk for Revit use.
    Employee
    loboarch
    Re: Poor 3-D graphics
    02-10-2012 10:57 AM in reply to: swells
    Sometimes when material layers are very thin the material beyond the thin one will "bleed through"  That may be what you are seeing.  It is hard to tell from the image you posted.
    You may also want to try turning off hardware acceleration and see if that help with the problem.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    New Member
    02-10-2012 01:20 PM in reply to: swells
    Your suggestion worked on both levels.  The material was bleeding through due to being so thin.  Turning off the Graphics Accelerator improved the appearance but bleed through was still noticable at the very thin portion only.
    By hiding the backing wall, the image clears up.
    Thanks for the tip.
