Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Plywood detail fill patteren I don't like! Rotate thefill?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you set the drafting fill to run this way if the componentis horizontal and it rotates with the plywood object if you angle it or it runs vertical?
Re: Plywood detail fill patteren I don't like! Rotate thefill?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Scott Womack
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Still not fixed in 2011 version...
Please tell me I just haven't found the correct option yet?
I know it's seems like a minor issue but tell that to my manager...
We can't use the Plywood component, drawing the pattern in lines now...
c
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've been told that the align with object options in regards to drafting hatch patterns only applies to system families, i.e. walls, floors, roofs.
You can make a model hatch pattern, however, the default plywood, and most other patterns I've tried become too dense and don't work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To get around this program error I have created another fill pattern and another plywood family to make a vertical plywood detail component. Is this the best way or only way to do this?
Chris
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am not saying that this is the best method, however I have seen someone, I can't recall where creating a Detail family with a array to represent the hatch.
This would allow the plywood to be rotated in any direction as it is not necessarily a hatch.
I have not tested this out on a real project, so I wouldn't know what the performance hit would be for having hundreds of these blocks in the model.
Just a thought though if the fill patterns don't work out for you.
K
BIM Coordinator
AEW Architects
Manchester, UK
If my post solves your issue, please accept this as a solution and give me a thumbs up!
