Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Plot syles. help
Options
- Highlight
- Email to a Friend
68 Views, 2 Replies
08-08-2004 07:57 AM
I´m planning on moving from ADT to Revit.
How do I set up a custom lineweight settings for printing.
I use acad.ctb in autocad to control the lineweight by colors. Is there anyway I can do something similiar in revit?
*Christie Landry [Autodesk]
Re: Plot syles. help
Options
- Highlight
- Email to a Friend
08-09-2004 08:21 AM in reply to:
lxgrunger
The beauty of Revit is that you aren't dealing with ctb files. You are
dealing with real line weights that are directly associated with the objects
when they are plotted.
For Autodesk Revit components, set the projection, and, if applicable, cut
Line Weights for the category. This enables you to control the display of
geometry when it is cut and not cut without the need to create separate
subcategories. For imported geometry layers, set the appropriate line
weight.
I hope this is helpful.
Christie Landry
Autodesk Revit Product Marketing Manager
"lxgrunger" wrote in message
news:503432.1091977092824.JavaMail.jive@jiveforum1 .autodesk.com...
*Aaron Rumple
Options
- Highlight
- Email to a Friend
08-09-2004 11:23 AM in reply to:
lxgrunger
My response to this question is always. Do your first project with the
default settings. Revit looks pretty good out of the box. Then you can
decide what needs to be adjusted.
"Christie Landry [Autodesk]" wrote in message
news:41179665$1_2@newsprd01...
objects
> weight.
> Christie Landry
