• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    New Member
    Phases
    50 Views, 1 Replies
    08-18-2004 06:02 PM
    I am fairly new at revit and currently I am interested in renovations. What am I required to do is an existing plan and a plan with the new extension.
    My problem is that I can not switch between phases. Once I use the demolition command, the walls stay that way and I am not able to view or print the existing plan.
    Please use plain text.
    *Scott Davis
    Re: Phases
    08-18-2004 08:56 PM in reply to: Alex S
    You need to set up additional views (make copies of the views) with phase filters. Each phase is a range in time. When you draw your inital model, set all those elements to the existing phase. Now duplicate the view, and set the phase filter to "Show Previous and demo" then use the demo tool. It will show the 'existing" items, and the demo items. Wehn done, duplicate the view again, and set the phase filter to "show previous and new" and se tthe phase to New construvtion. Now draw in the new stuff, and the view will show only the exisitng elements, and the new elements. "Alex S" wrote in message news:349495.1092877392531.JavaMail.jive@jiveforum2.autodesk.com... > I am fairly new at revit and currently I am interested in renovations. What am I required to do is an existing plan and a plan with the new extension. > > My problem is that I can not switch between phases. Once I use the demolition command, the walls stay that way and I am not able to view or print the existing plan.
