• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Active Contributor
    rlabib
    Phases question
    104 Views, 2 Replies
    01-24-2013 06:15 AM
    I'm in the process of creating a new template for our office , so far we used the Architectural Template that come with Revit. And I like that has only two phases (New and Existing) . However I opened the construction template that comes with revit and I found at least 6 phase setup. And I would appreciate it if someone of experts here tells me what is the best way to handle phases? How many phases should I setup. We do a lot of renovation projects , so we always have existing and new elements.
    Thanks in advance
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Phases question
    01-25-2013 12:32 PM in reply to: rlabib
    rlabib wrote:
    How many phases should I setup. ...
    That question is really for your own office. It depends on the kind of work that your office does. That will give you an idea about the phases you need for your template.
    Planta1 Revit Online Consulting | info@planta1.com
    Employee
    loboarch
    Re: Phases question
    01-25-2013 12:48 PM in reply to: rlabib
    You can take a look at this wikihelp article for some additional phasing explination and an example project showing the setup.
    http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Example_Project_to_Illustrate_Phasing
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
