Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Parapet Interior wall finish above roof line
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
290 Views, 1 Replies
08-21-2012 04:50 PM
I have an exterior wall with plaster and lathe on the exterior, and gyp board on the inside. When I edit the wall structure, and modify the layers so that I can take the interior wall finish only up to the sheathing line, the wall does not join at the corners properly. It leaves a gap for the interior fininsh at a corner above the sheathing line when looking in 3d. Any suggestions? What are you all doing with parpet walls and the interior finishes above the roof line?
Re: Parapet Interior wall finish above roof line
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-23-2012 01:01 PM in reply to:
vitus56
I have two suggestions. 1. Create a second wall type for above the parapet or 2. Use masking regions to hide the what you dont want to see above the parapet.
Thanks for posting.
Alan Quinn
Support Specialist
Product Support
