04:50 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an exterior wall with plaster and lathe on the exterior, and gyp board on the inside. When I edit the wall structure, and modify the layers so that I can take the interior wall finish only up to the sheathing line, the wall does not join at the corners properly. It leaves a gap for the interior fininsh at a corner above the sheathing line when looking in 3d. Any suggestions? What are you all doing with parpet walls and the interior finishes above the roof line?
