• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    IMCornish
    Parametrical Control of the Radius in a Radial Array
    82 Views, 2 Replies
    01-23-2013 02:05 PM
    I am having trouble trying to parametrically control the radius of an array of holes in a steel plate which is part of a family I am creating.  I need to alter the radial distance of the holes, and the diameter of the holes, depending on the family type.  Whilst it is straightforward to control the diameter of each hole, controling the radial distance from the common centre is alluding me.
    The first issue is locking the initial circle, to be arrayed, at a parametric distance.  I have tried all manner of combinations of reference lines and reference planes, some of which appear to flex prior to creating the array but I am constantly getting a 'Constraints are not satisfied' error message.
    Any ideas please?
    Andrew Robertson
    Chartered Architect
    Robertson Partnership
    Truro. UK
    Please use plain text.
    Valued Mentor
    AJA14
    Re: Parametrical Control of the Radius in a Radial Array
    01-24-2013 04:06 AM in reply to: IMCornish
    Hi. I'm not sure if we can help without the actual file to check, but I had an issue like this once, and if I am not mistaken, try creating your radial elements in a separate family, and then nest them in the original family and constrain them using reference lines. Give it a shot.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    01-24-2013 04:38 AM in reply to: IMCornish
    Without seeing the file it is difficult to diagnose, however when I need to use arrays, I find it far more useful to have arrayed elements within a nested file.  This won't work is you are array a void though.
    Disregarding this...
    If you are controlling the radius of an array.  Create the polar array a normal.  Select the array, the temporary radius dimension will appear.  Convert this to a permanent dimension by clicking the little dim icon.  This dimension can now be changed to a length parameter.
    This should control the radius of the array.
    Hope this helps.
    Kevin
    If this solve your issue, please accept this as a solution
    Kevin Fielding
    BIM Coordinator
    AEW Architects
    Manchester, UK
    If my post solves your issue, please accept this as a solution and give me a thumbs up!
