• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    PDF floorplan, import as revit underlay?
    11525 Views, 19 Replies
    02-27-2010 07:02 PM
    Can I import a florrplan in PDF format to begin a drawing?
    Please use plain text.
    Valued Mentor
    vector2
    Re: PDF floorplan, import as revit underlay?
    02-28-2010 04:48 AM in reply to: KJFortin
    KJFortin-
    smart thinking..
    yes- a PDF floorplan is a very good way to start
    a revit project.. but you must first convert the PDF
    to a jpeg image.. you also need to know just one
    dimension in that image- and create two points
    in revit with that dimension in a floorplan view-
    and then align the image to that dimension..
    *cdv
    02-28-2010 04:50 AM in reply to: KJFortin
    Unfortunately you can not import pdf's into Revit. That has been on my wish
    list for awhile. If you have the suite or access to Autocad 2010 you can
    import into autocad, trace over what you need and then import the dwg file.
    "KJFortin" wrote in message news:6345675@discussion.autodesk.com...
    Valued Mentor
    vector2
    02-28-2010 05:15 AM in reply to: KJFortin
    KJFortin-
    the worst thing you can do is import any DWG into revit..
    and there is no need for that anyway..
    if you don't have adobe acrobat to convert the PDF to an image-
    just printscreen it..
    or you can just LOOK at the PDF and draw the walls
    according to what you see and then dimension them
    the way you want..
    *The Dark Princess
    02-28-2010 06:12 AM in reply to: KJFortin
    why?
    scaling off a jpeg has 1/10000 the accuracy of a drawing.
    TDP
    First things first, but not necessarily in that order.
    The Doctor
    wrote in message news:6345777@discussion.autodesk.com...
    KJFortin-
    the way you want..
    *Terry W. Dotson
    02-28-2010 08:39 AM in reply to: KJFortin
    You can if you convert them to DWGs first.
    http://www.dotsoft.com/revit/pdf2revit.htm
    Terry
    *The Dark Princess
    02-28-2010 09:07 AM in reply to: KJFortin
    LOL!
    TDP
    The Doctor
    "Terry W. Dotson" wrote in message
    news:6345825@discussion.autodesk.com...
    Terry
    Valued Mentor
    vector2
    02-28-2010 11:57 AM in reply to: KJFortin
    TDP-
    two good questions-
    1. isn't tracing an image to build walls in revit inaccurate?
    2. what is wrong with bringing DWGs into revit?
    answer:
    1. the way you start a revit project is to start by
    building the walls.. the idea is to put the walls
    in their approximate location and then place grid
    lines somewhere near those walls and then align
    and lock those grid lines to the walls- and then
    dimension those grid lines with the walls locked
    to those grids..
    and this revolutionary procedure makes it possible
    to start a project from a pencil sketch of a floorplan..
    importing that sketch into revit as an image and tracing
    over it just makes it a little more convenient than having
    the printed sketch next to your monitor- but not all
    that much.. because again- all you want to do is
    place your walls in their approximate location to start..
    there is no point in trying to place accurate lines into
    revit for starting walls- because the accuracy of those
    lines means nothing to revit..
    2. DWG in revit?- don't do it.
    trust me.. don't EVER import DWG's into your revit project files..
    yes revit can import DWG files- but it is seriously bad practice..
    it brings with them a myriad of layers/objects that get converted to
    linetypes- and your materials- text styles- filled regions- etc. etc.-
    gets ALL screwed up.. basically your revit file turns into a major
    case of FUBAR..
    you CAN- if you want to save a few minutes building a site
    plan- LINK a DWG into a separate session of revit and use
    it for a temporary underlay to create a toposurface and
    "revitize" it and then LINK that revit site file to your building file..
    i realize this does not satisfy the "feelings" of CAD people
    who yearn to make AutoCAD part of revit- but it's the right way
    to do it..
    *The Dark Princess
    02-28-2010 06:28 PM in reply to: KJFortin
    it is easuly done and incredibly accurate - far more accurate than revit.
    but this is beyond your knowledge and possibly beyond your comprehension. as
    a person who envisioned bim before you were born i can say that with ease.
    as a person who worked in bim in 1983 I can say that. if you want to see my
    work google meyerson symphony center dallas. that was the start of bim for
    me.
    TDP
    The Doctor
    wrote in message news:6345847@discussion.autodesk.com...
    TDP-
    two good questions-
    answer:
    to those grids..
    case of FUBAR..
    to do it..
    Valued Mentor
    vector2
    02-28-2010 06:37 PM in reply to: KJFortin
    TDP-
    let me put this into slightly different words for you
    because this is one of the master keys to making
    the transistion from AutoCAD to revit..
    to those grids..
    this means you can start a project from a pencil
    sketch or any CAD sketch of a floorplan..
    the project..
    2. don't EVER import DWG's into your revit project..
    case of FUBAR..
    "revitize" it- and then LINK that revit site file to your building file..
