• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Matt Stachoni
    One model vs linked models?
    402 Views, 18 Replies
    04-22-2010 07:34 PM
    I have a client who has everyone in-house - architects, interior designers, MEP,
    and structural. Even civil. They rarely use outside consultants.
    We are debating whether to do everything in one model or have everyone work in
    their own space and link things together.
    Thoughts?
    Matt
    matt@stachoni.com
    Please use plain text.
    Alfredo_Medina
    Re: One model vs linked models?
    04-22-2010 08:49 PM in reply to: *Matt Stachoni
    I would vote for having linked models. I can think of these 3 reasons:
    1) Hierarchy of roles: If the models are separated, only a few more experienced users or just one general coordinator will be responsible for setting up how the different models work together, instead of taking the risk of allowing many users of different departments with different levels of experience and knowledge to save content to a central file.
    2) Efficiency: Chief of departments will feel more comfortable and concentrated on their projects knowing that only their team of collaborators are taking care of "their project" first, without having to deal with other departments' stuff (and staff) in their way all the time.
    4) Disaster recovery: Putting eggs in separated baskets is better than putting all the eggs in the same basket. If anything goes wrong with the super model, is a disaster. If we have different models, we can link them together again at any time.
    Alfredo Medina
    info@planta1.com
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Mentor
    04-23-2010 05:42 AM in reply to: *Matt Stachoni
    The interior designers that work for the firm I work for use Revit everyday to do their designs. Furniture layouts, Floor and wall patterns, you name it. They prefer Revit to CAD for their work. Edited by: Discussion_Admin on Apr 23, 2010 10:30 AM
    Valued Mentor
    04-23-2010 05:57 AM in reply to: *Matt Stachoni
    > {quote:title=Guest wrote:}{quote}
    > Thoughts?
    > Matt
    > matt@stachoni.com
    Hey Matt
    I would still recommend having them work in their own models and link them together. Unless they are working on a very small project. I also like the reason's Alfredo gave as to why you should separate.
    I hope things work out for you client.
    *Matt Stachoni
    04-23-2010 06:16 AM in reply to: *Matt Stachoni
    Thanks, Alfredo.
    Some more backgroud:
    On this particular project (their first Revit project after initial training),
    it's small enough that they could all work in the same file without tripping
    over anyone. It's basically being handled by one or two architects /
    architectural designers, one structural engineer, one mechanical engineer, and
    one electrical / lighting designer.
    So far they are working in a combined model using worksharing. It was
    established before I got involved in training, so it was tough to change course
    without a lot of rework and they were under a time constraint. (Hint: If you are
    going to use an actual project for your initial training, make sure your
    deadline isn't three days after training is finished).
    Regarding disaster recovery, because all users are worksharing with a local
    file, there are numerous full-project backups peppered around the office, so
    that's no big deal. So far the project database is around 15MB, which is
    manageable.
    The benefits of a combined model in this case are that there isn't any
    copy/monitor issue to deal with. The project is also in a somewhat early stage
    of design development - they are still scooching column grids and TOS around to
    make things fit. In a single model, that really helps with coordination instead
    of doing copy/monitor.
    The biggest issues so far are due to how the project was started; the structural
    person created it using Revit Structure. Thus, they are living with the legacy
    of the template used:
    1. When creating new Views, they are set to a Discpline of Structural and use a
    Structural default view template. This gets really old after about 4 seconds.
    2. None of the fittings required for MEP are in the file. We had to transfer
    project standards from a project built from the mechanical default template,
    import a ton of components, set up MEP settings explicitly for duct families and
    so on.
    Other than those two things, it's actually working out fairly well. Because the
    team is small (< 8 people total) it's probably more appropriate for things to be
    centralized. Anything bigger and I would recommend separating the models.
    Matt
    matt@stachoni.com
    >Alfredo Medina
    >info@planta1.com
    *Matt Dillon
    04-23-2010 06:39 AM in reply to: *Matt Stachoni
    I frequently have interior designers in my classes, and I frequently go to
    my clients offices to do on-site mentoring which usually involves at least
    one person from the interiors department.
    You might want to go check your research again, there, Sparky.
    "vector2" wrote in message news:6379129@discussion.autodesk.com...
    > it just seems like if "lots of other places do it"-
    > there would be some mention of that somewhere
    > on the web..
    *Doug Bowers
    04-23-2010 06:40 AM in reply to: *Matt Stachoni
    Matt,
    Given the information that you have provided on the size of the project, I
    would lean toward the one model with worksharing. That also helps with the
    connectivity issues that typically exist in pre-2011 releases between the
    architectural and MEP models for things like plumbing fixtures and light
    fixtures.
    Note that I think this because it is such a small project. For most
    projects, I recommend separate models for pretty much the same reasons that
    Alfredo mentioned.
    It sounds an interesting situation given the short timeframe on the first
    project.
    Doug
    www.dougbowersconsulting.com
    blog: http://aectechtalk.wordpress.com
    "Matt Stachoni" <...> wrote in message
    news:6379116@discussion.autodesk.com...
    Thanks, Alfredo.
    training),
    and
    course
    are
    manageable.
    stage
    to
    instead
    structural
    legacy
    use a
    seconds.
    and
    so on.
    the
    to be
    Matt
    matt@stachoni.com
    >Alfredo Medina
    >info@planta1.com
    *Matt Dillon
    04-23-2010 06:43 AM in reply to: *Matt Stachoni
    Linked models give you the ability to better manage model size. The improved
    copy/monitor tools in RMEP 2011 and the ability to get better control of
    workset visibility and loading in linked models also may indicate that
    breaking it up into separate models would be more effective than in previous
    releases.
    Of course, if you put everything in one model, that would give the
    architectural peeps the ability to move that pesky AHU unit somewhere else
    where it isn't so much in the way... or get rid of that ugly cooling tower
    on top of the building.
    Oh... wait...
    Seriously, I would consider splitting the MEP stuff out - maybe leave the
    Arch, Interiors and Structural in the same model. Possibly split out the
    structural into a separate model, but definitely leave the interiors in the
    architectural model.
    "Matt Stachoni" wrote in message
    news:6378898@discussion.autodesk.com...
    > designers, MEP,
    > work in
    > Thoughts?
    > Matt
    > matt@stachoni.com
    *Doug Bowers
    I agree. I have also had interior designers involved in Revit training.
    They do use it.
    Doug
    "Matt Dillon" wrote in message
    news:6379144@discussion.autodesk.com...
    > on the web..
    *Lance W.
    04-23-2010 07:00 AM in reply to: *Matt Stachoni
    the only real problem I see with the interior designers is that some of them
    will start messing around with the walls to get them to look right. Best
    idea might be to have them in their own space with linked files too, just
    for different reasons.
    Lance W.
    news:6379145@discussion.autodesk.com...
    > improved
    > previous
    > releases.
    > Oh... wait...
    > the
    >> designers, MEP,
    >> work in
    >> Thoughts?
    >> Matt
    >> matt@stachoni.com
