• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    lockmote
    No template on my Revit Architecture
    23425 Views, 29 Replies
    04-10-2011 09:26 AM
    hey guys . I just want to ask you . After I installed my Revit Architecture 2012 and I open it
    It always say "Default Template File Invalid"
    bla bla bla
    like on this pict
    Can you guys help me out ?
    I'm browsing to my computer and I don't find any file that *.rte anywhere
    Please use plain text.
    Active Contributor
    edwardnoael
    Re: no template on my revit architecture 2012
    04-11-2011 01:01 AM in reply to: lockmote
    Have the same problem.. what to do?
    Valued Contributor
    04-11-2011 04:04 AM in reply to: edwardnoael
    Same problem here,
    Two solutions:
    1) use RST 2011 template
    2) Open the default project and save as template.
    But still the question remains, from where to download the 2012 templates?
    Raghavendra Bhat
    rnbhat1@gmail.com
    New Member
    lockmote
    04-11-2011 05:49 AM in reply to: lockmote
    If I use the Revit Architecture 2011 template, will it work perfectly ? Will the program crash or not ?
    and where I can download Revit Architecture 2011's template ? Can you give me the link ?
    because I'm confused (-.-)"
    yes, why autodesk doesn't give the Revit Architecture 2012's templates. They just make us confused of that template
    btw, I've downloaded the Revit Architecture 2011 Imperial Template
    can this default.rte be the right one for my template for now ?
    http://seek.autodesk.com/product/locale/adsk/revit/families/arch/empty/Revit_ARC1157
    Active Member
    04-17-2011 01:04 AM in reply to: lockmote
    Look for the Templates at the following location: C:/ProgramData/Autodesk/RAC2012/Templates/Canada
    There I found four, two of them default.  Hope it helps.
    Alex
    Member
    09-21-2011 01:01 AM in reply to: alex_k07
    OK I need links to download metric templates, please.  I'd prefer not to have to download - bandwith issues - so if it is hidden somewhere on the installation disk...
    Please also tell me where to place them so they can be picked up as default  - in C:/Program Data or somewhere else?
    It's OK for people who had 2011 before, but what about those who don't have 2011 on their computers?
    New Member
    mindaugas1988
    12-08-2011 06:45 AM in reply to: tertiab
    the same problem for me, I am not able to start working with revit, I am sure that it will help a lot for my studies, but from where get all the templates, and doors, windows, wall predefined models?
    Product Support
    12-11-2011 10:57 PM in reply to: mindaugas1988
    You could go through uninstall > add or remove components and adding some other libraries which were missed during installation.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Shiny Stephen
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    mindaugas1988
    12-12-2011 03:29 AM in reply to: lockmote
    thanks for the answer. So it means, that normally in the student version of Revit Architecture 2012 libraries and templates should be included? It was my mistake that I install it wrong? :smileyhappy:
    l.tucker
    12-12-2011 11:33 AM in reply to: mindaugas1988
    It usually installs alright, but sometimes the content libraries don't install. For 2011 and years before, you can download the libraries from http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13192741. For 2012, just go to Control Panel -> Add/Remove Programs -> Revit Architecure 2012 -> Change/Remove. Once in there, you should be able to add components to your install, such as the content libraries.
