• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Need Help!!! Revit 2011 won't start!!
    412 Views, 4 Replies
    02-02-2011 07:19 AM
    I've tried to remove this file and it does not apperar in the folder
    c:\Documents and Settings\%USERNAME%\Local Settings\Application Data\Autodesk\Revit\Autodesk Revit Architecture 2010\ENU\Components\WebServices\WSCommCntrData.xm
    I also deleted the webclient folder from the registry and nothing.
    My processor supports SSE2 instructions too!!!!!
    Any other ideas????
    Please use plain text.
    Distinguished Contributor
    shawn
    Re: Need Help!!! Revit 2011 won't start!!
    02-02-2011 08:10 AM in reply to: Loomsdak
    Sorry sir,
    I was going to try and offer a useful suggestion like make sure your license hasn't expired, but after reading your post, I have not idea what the he** you're talking about. But I'm not really an IT guy. Unless this is a dialog that's already in process with others more knowledgeable about such things, perhaps you could provide a bit of back ground and context.
    Good luck.
    Member
    02-02-2011 08:49 AM in reply to: shawn
    OK. I intalled revit 2011 and it won't pass the splash screen. It crashes after it appears.
    shawn
    02-06-2011 11:13 PM in reply to: Loomsdak
    My hunch is that there is either something currupted in the installation of the software, or you have a hardware issue (as in dammaged or incompatible components). Obviously Revit isn't supposed to do this. You might also look into security software issues or viruses.
    Sorry I can't be of more help. Good luck.
    Shawn Graham
    Designer.
    *Expert Elite*
    DarrenP
    02-07-2011 07:02 AM in reply to: shawn
