• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Moving objects between object styles
    161 Views, 5 Replies
    09-14-2012 06:47 AM
    Is it possible to move a wall to a different object style?
    Im currently setting out a toilet suite and would like to place the cubicle partitions in a more appropriate object style.
    Regards
    Christopher Alan Pitt
    Frank Shaw Associates
    Please use plain text.
    Employee
    loboarch
    Re: Moving objects between object styles
    09-14-2012 12:27 PM in reply to: chris.pitt
    Object categories are not editable.  If you create an object as a "Wall" you can move it to another category.  You would have to create a custom family in the category you want if you do not want a toilet partition in the wall category.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Active Contributor
    09-17-2012 06:16 AM in reply to: loboarch
    Noted, but can I assemble system families into a loadable family?
    Do do what I want simply I need to use walls, doors and curtain walls togethor.
    Regards
    Employee
    loboarch
    09-17-2012 06:25 AM in reply to: chris.pitt
    You can use system families as part of the family definition.  You could create assemblies or groups in a template and then the grouping of elements could be placed by creating an instance of the assembly or group in your project.  The one drawback of this method is that it really can't be managed in a library or easily redefined in an on going project.
    Jeff Hanson
    Active Contributor
    09-17-2012 07:17 AM in reply to: loboarch
    Sorry but I'm new to this and patently dumb.  How do I get a system family into a loadable family? It's not immediately obvious and copy/ paste throws up an error.  Do I need to use a particular family template?
    Regards
    Employee
    loboarch
    09-17-2012 07:21 AM in reply to: chris.pitt
    Oops.  That was a typo it meant to say you CAN"T place a system family into a componnet family file.  Sorry about that.
    Jeff Hanson
