• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Moving introduce “Can't keep elements joined”,
    294 Views, 3 Replies
    10-06-2012 02:47 PM
    I tried to move my drawing to make it at the center of the elevation tags but I have a message saying “can't keep elements joined”
    What is the effect of accepting or rejecting this message?
    Also, I’m wondering if there is a command that place the drawing at the center of the elevation tags.
    Thank you for the help,
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Active Contributor
    arya2013
    Re: Moving introduce “Can't keep elements joined”,
    10-08-2012 02:48 AM in reply to: JamaL9722060
    Two approaches to this problem however it seems to me you think
    1 - First, get into a 3D view, and click and drag to select all the elements.
    - The 2D view, for example, plane (level) down the Ctrl key elements of the plan and go with the next two, for example,
    choose a  Dimenssion line.
    You can now use the Move Tool to move the elements.
    2 - The second method:
    You can open a new file and the files in it to Link.
    10-08-2012 05:31 AM in reply to: JamaL9722060
    Moving the entire building (while possible) is not recommended, especially for such as trivial purpose. The error you are getting there means that some of your elements are going to lose their association with each other. Not good. Also, there are many issues that will crop up, especially with others who are coordinating with your Model. Additionally, it is probable that may not select every element, which will cause more problems of course. And lastly, moving the entire model will cause significant problems with your Annotations in your Views. You'd have to go to each one to relocate any text, generic annotations, etc.
    Simple answer: DO NOT move the model. Instead, mode the Elevation Tags to accommodate your model's position.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    10-08-2012 01:22 PM in reply to: CADastrophe
    Many thanks for the help guys.
    Perfect. Then better to move the tags rather than the drawing. this answers my question.
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
