• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Moving a cutrain wall
    106 Views, 2 Replies
    12-04-2012 04:50 PM
    I am trying to align the curtain wall with the edge of the concrete slab/face of wood framed wall (Core).  I have tried to align and move however the whole wall moves as well as the edge of the slab. Any idea on how I can move the Curtain wall leaving the other elements in place?
    Please use plain text.
    Active Contributor
    Re: Moving a cutrain wall
    12-04-2012 06:03 PM in reply to: cadmansteve
    What you need to do is select the curtain wall jamb (or mullion as Revit calls it) and choose the edit type button and play with the Offset value until you get the desired result.  You can repeat this with the Curtain Panel.  You may need use the tab button to select the Curtain Panel
    http://www.screencast.com/t/yeOFcYmalz
    _________________________________________________________________
    KarelCAD Application Support Specialist
    Alfredo_Medina
    12-04-2012 06:21 PM in reply to: cadmansteve
    You can move the curtain wall without moving the adjacent wall by either one of these methods:
    • Move > Disjoin > select the curtain wall > move it.
    • Select the curtain wall > find the blue dot > right click > Disallow join > move the curtain wall.
    Planta1 Revit Online Consulting | info@planta1.com
