• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Modify Ribbon error
    3489 Views, 42 Replies
    08-26-2012 06:53 PM
    I will try to explain my situation the best as I can.
    When an item is selected in the model, the modify ribbon changes the icon for the specific object. But when I'm selecting an item there are no additional icons. As you can see the topography is selected and the modify tab is available but no modification icons. Is does the same with any other object.
    I have reinstall Revit, I have tried registry fix, I have uninstall the frame network 4.5 beta, I have upgraded the video card drivers, I have format all the pc and installing a fresh Windows 8 costumer preview and have run it with compatibility mode in windows 7 and vista. The software (Revit) was working fine and for no apparent  reason it started with this problem.
    The pc is running
    Intel i7 940
    12 GB ram
    Windows 8 64-bit OS
    Ati Radeon HD 4870 x2
    3 Western Digital Raptors in Raid-5
    Please use plain text.
    Employee
    Re: Modify Ribbon error
    08-27-2012 07:53 AM in reply to: arnel01
    Member
    08-29-2012 05:32 AM in reply to: arnel01
    I used a .Net Framework 4.5 removal program. and uninstalled from the program list. This problem persists. It makes the program practically unusable at the moment. Is there any fix?
    LisaDrago
    08-30-2012 04:48 AM in reply to: Cribbert000
    You can try resetting the ribbon:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16825244&linkID=9243099
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    Member
    08-30-2012 02:08 PM in reply to: LisaDrago
    I tried using the script, but the behavior of the ribbon remains the same. It never loads the context menu correctly. Is there some kind of patch we can get for this soon? I've tested on both 2012 and 2013. Same bug.
    LisaDrago
    08-30-2012 02:54 PM in reply to: Cribbert000
    Have you tried to manually renaming the uistate.dat file?
    This will force the ribbon to reset.
    I have not heard of people having issues with the ribbon.
    LD
    Member
    08-31-2012 02:41 AM in reply to: LisaDrago
    Tried renaming that file manually. It made a new one on the next launch, but the bug is still there.
    Employee
    08-31-2012 05:01 AM in reply to: Cribbert000
    The behavior and screen capture you mentioned seem to match what happens when .NET 4.5 is installed [or was installed] on the workstation.
    Can you please manually uninstall .NET 4.5 if it is still on your workstation and then use the .NET 4.0 web installer from Microsoft at the link below?
    Microsoft .NET Framework 4 Client Profile (Web Installer)
    Ryan Duell
    Revit Clinic
    @revitclinic
    Member
    08-31-2012 11:03 AM in reply to: ryan.duell
    I removed .net 4.5 with a special remover that microsoft pointed out and uninstalled it from the programs menu.
    The installer you pointed out won't run saying that windows already has .net 4 or that a higher version is already there. This sounds like a bigger windows 8 problem with removing .net 4.5.
    Has anyone used revit 2012 or 2013 on Windows 8 without this bug?
    Member
    09-01-2012 05:34 AM in reply to: arnel01
    At the moment I have tried many options as I described in the beginning. I tried the .NET removing tool and it didn't work. I manually located the registry containing the installation package and delete it, it didn't work. I'm just format the computer and I'm stalling a fresh copy of windows 8 costumer preview and of course everything new. This copy of windows 8 have .NET 4.5 by default.
    The behavior has been with modify icons. Some times by clicking an object the icons do not appear or show the icons to modify the previous object. I used to cycle trough all the view and show the appropriate icons to modify the selected object. It is complicated to waste so much time every time you need to change something. But recently the icons where not available as you can see in the picture at the beginning.
    Solutions I have tried
    1. Unistalling .NET 4.5
    2. Re installig Revit 2013 (several times)
    3. Unistallig and Re-installing Revit 2013
    4. Backing up revit registry and deleting the display registry
    5. Fixing the registry with a registry software
    6. Formating the PC and isntalling a Fresh copy of windows.
    7. Running windows compatibility mode.
    8. Updating video card drivers
    I do appreciate all the reply but the problem has not been solved yet.
