• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Valued Contributor
    kate_vanhout
    Model Text
    216 Views, 6 Replies
    10-31-2012 12:38 PM
    I am using Revit Architecture 2013 and I was wondering if there is a way to make model text vertical instead of horizontal? I am creating an address stone that we put on the front of our homes but the nunbers need to run vertically.  I am creating an address stone family and would like to be able to have the numbered address a changeable parameter but if I change the numbers they go back to being horizontal.  Any suggestions?
    Please use plain text.
    Re: Model Text
    10-31-2012 01:13 PM in reply to: kate_vanhout
    Individual Model Text letters stacked vertically?
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Re: Model Text
    10-31-2012 01:34 PM in reply to: ccollins
    ccollins wrote:
    "Individual Model Text letters stacked vertically?"
    I would agree. Attached is an example family that can take a 3-digit number as a parameter value and then split it up amongst three separate Model Text elements. Revit 2013.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Contributor
    kate_vanhout
    Re: Model Text
    10-31-2012 02:47 PM in reply to: CADastrophe
    Sweet! Thanks so much, I had no idea you could have a formula like that... this is exactly what I was looking for! I don't think I would have been able to figure this out on my own!
    Alfredo_Medina
    Re: Model Text
    10-31-2012 05:52 PM in reply to: kate_vanhout
    oh, if we just had a little bit of the same functions that were available in the old-an-good Autolisp, we didn't need to do those long formulas in Revit. If we just had something such as "stoi" (to convert string to integer), or "strcat" (for concatenating strings)... OK, I will keep dreaming...:smileysad:
    Planta1 Revit Online Consulting | info@planta1.com
    Re: Model Text
    11-01-2012 05:24 AM in reply to: Alfredo_Medina
    The limitations of the formulaic functions is horrible thing, indeed, and has been one of my top 5 problems with Revit.
    Take a peek at the attachment in this thread to see a monster I had created as a result...
    Alfredo_Medina
    Re: Model Text
    11-01-2012 05:57 AM in reply to: CADastrophe
    Holy Cow! That is a monster formula. As I said, if we just had 1/10th of the functions that we used to have in that old programming language, formulas in Revit would be so much easier.
