• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    CliveBroadhurst4576
    Missing Render Button in Revit 2013
    304 Views, 4 Replies
    01-22-2013 04:25 AM
    For no apparent reason the Render Button at the bottom of the view frame has disappeared. With RayTrace I just get a black screen. It was all working fine then suddenly the problem occurred.
    There doesn't seem to be anything wrong with the PC - I can render in MAX Design as normal.
    Any ideas would be appreciated ...
    Please use plain text.
    CliveBroadhurst4576
    Re: Missing Render Button in Revit 2013
    01-22-2013 04:33 AM in reply to: CliveBroadhurst4576
    It's something about textures isn't it?
    There is no difference between setting the view to Shaded and Realistic ...
    CliveBroadhurst4576
    01-22-2013 04:42 AM in reply to: CliveBroadhurst4576
    I can't edit Materials either ....
    CliveBroadhurst4576
    01-22-2013 06:52 AM in reply to: CliveBroadhurst4576
    I tried a 'Repair' from the Installation - that said repair was successful - but if hasn't solved the problem ...
    New Member
    01-27-2013 12:45 PM in reply to: CliveBroadhurst4576
    Not sure if this is what your talking about, but I randomly lost my Render to cloud button on the ribobn.  see attached image.  Ray trace working fine though (not that I ever use it)... I'm logged in to subscription center and have rebooted multiple times.
