• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    smikrut11
    Material Tags & List
    205 Views, 3 Replies
    08-23-2012 11:49 AM
    I have a rather lengthy question I need some help with.
    I am working on setting up an office standard project template for a new company as they make the transition from CAD to Revit Architecture 2012. In their elevations (both interior and exterior), sections, and details they use material tags and a materials list. For example; an exterior elevation has a tag with the number 09 24 00 called out with a leader arrow pointing to the exterior facade. That Con-doc number is then referenced elsewhere on the drawing sheet in a materials list  at 09 24 00 - Lath & Stucco.
    This is the first time I have ever come across a company that notes there drawings in this way. I have am more familiar with calling out materials with a simple leader arrow and note.
    My question is, is it possible to duplicate this material tag as well as create a schedule that lists these Con-doc numbers and their corresponding material? Does each material in Revit Architecture have spec section numbers built into it, or would I have to manually enter each Con-doc number into the individual materials?
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Material Tags & List
    08-23-2012 12:04 PM in reply to: smikrut11
    If I understand correctly, what you are describing is keynotes. Please check Wikihelp for more information on that topic.
    Planta1 Revit Online Consulting | info@planta1.com
    Member
    jbayne
    10-18-2012 10:06 AM in reply to: Alfredo_Medina
    I just looked thru Wikihelp and it was not much help on this matter.
     What I am looking for is a list of common materials (GWB, Metal Stud, Plywood) that would already have the keynote section filled in. Is this something each office needs to go thru during initial setup?
    10-19-2012 05:56 AM in reply to: smikrut11
    e-SPECS provides keynotes for MasterSpec and other commercial masters as well as management of master keynotes, automatic filtering for project specific list of keynotes, and advanced assignment and validation within Revit.  Have you already checked into the e-SPECS keynoting functionality?
    Yes, I am with InterSpec who develops e-SPECS.  I am also hoping this functionality helps firms save time and money in coordinating their construction docs while reducing the extra manual steps required.
    Seamus McGrady  smcgrady@e-SPECS.com  www.e-SPECS.com
