• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    david.rosen
    Making it easier to read what's on the screen
    120 Views, 1 Replies
    02-06-2012 10:36 AM
    The resolution of my monitor is set to the recommended resolution of 1920 x 1080. The default text size of 100% is too small. One of the preset options is to set the text at 125%. That works find in Revit Architecture 2012. BUT, I need the text to be a tad larger. If I set the text to 130% with a custom text size, something weird happens in Revit. The "status" bar at the bottom of the editing screen distorts the text. Some other weird things happen as well. Is text size in Revit hardwired? That's really frustrating.
    Distinguished Contributor
    Re: Making it easier to read what's on the screen
    02-16-2012 02:16 PM in reply to: david.rosen
    To achieve what you are looking for you would have to research how to change the font size in windows.
    We strongly recommend against it as it could cause other issues and you might have to do a clean unistall of Revit.
    Hope that helps.
