• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    MATERIALS LIBRARY
    302 Views, 5 Replies
    09-26-2012 09:37 PM
    It takes forever to open the materials library, could it be that a purge is in order?
    Please use plain text.
    Product Support
    fernanda.firman
    Re: MATERIALS LIBRARY
    10-02-2012 02:32 PM in reply to: madone55
    That doesn't seems to be an issue with the purge.
    What version are you using?
    What do you mean by opening the library? Can yo udescribe the steps?
    Where is your library located? On your hard drive? Server?
    Fernanda Lima Firman
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    10-02-2012 04:33 PM in reply to: fernanda.firman
    I'm using Revit Architecture 2013.
    I materials library is on C drive (not sure how to navigate threre though).
    Opening the Library: Clicking the MANAGE tab then clicking 'Materials'.
    Product Support
    fernanda.firman
    10-31-2012 07:44 PM in reply to: madone55
    Are you still having the issue?
    Have you tried repairing the libray?
    It could be that your computer is not handling Revit.
    Can you please send us your computer specs?
    Autodesk, Inc.
    Revit Clinic
    10-31-2012 07:49 PM in reply to: madone55
    Thank you, its all good now. I think the real issue was the congestion of my windows 'temp..' folder. I'm suspicious that revit leaves a whole pile of junk in the temp folder; it made a huge difference when all the files in the temp folder were deleted.
    Product Support
    fernanda.firman
    10-31-2012 08:17 PM in reply to: madone55
    Glad to hear that and thanks for sharing the solution!
    Autodesk, Inc.
    Revit Clinic
