• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    jaime09
    Loadlibrary failed with error 126: The specified module could not be found.
    5116 Views, 7 Replies
    08-15-2011 12:29 PM
    this message appears everytime i try to load a different type of door or window, then crashes all together. as far as i know its not a hardware issue, i use catalyts version 9.1 i have tried to repair and reinstal revit but nothing works if this question is somewhere else post it please.
    Thanks, J
    Please use plain text.
    Employee
    Re: Loadlibrary failed with error 126: The specified module could not be found.
    08-16-2011 12:30 PM in reply to: jaime09
    This error is most commonly reported [across a number of applications] related to an ATI driver or OpenGL conflict.
    1.  I would ensure to upgrade to the latest certified driver from the download list below:
    http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
    2.  If the issue persists, ensure Revit Hardware Acceleration is disabled, under Options > Graphics.  Close \ re-open Revit, and see if the behavior persists.
    3.  Also, try ending any ATI Control Panel or similar applications running.
    Thank you,
    Ryan Duell
    Autodesk, Inc.
    Revit Clinic
    @revitclinic
    New Member
    04-17-2012 04:15 AM in reply to: jaime09
    my computer is brand new, an expencive acer, dosent that come with the  the latest certified driver ? can i download a driver for free ?
    i have ensured that Revit Hardware Acceleration is disabled, but it dident help
    i dont think i have any ATI Control Panel or similar applications running.
    New Member
    05-14-2012 10:15 AM in reply to: jaime09
    I have the Same Issue with a new Acer that has Amd HD 7670M display adapter
    New Member
    05-16-2012 05:52 PM in reply to: jaime09
    I've got the same problem.  Also with a new ACER laptop. Any answers on how to fix this yet?
    05-18-2012 10:18 AM in reply to: jaime09
    Not sure if you have found a solution.  I have the same laptop with the AMD Radeon HD 7670M video card. I found the following link in which you can download a .reg file that will fix this error.  Don't ask me why, but the solution worked on my laptop.
    http://www.withinwindows.com/2012/03/31/loadlibrary-failed-with-error-126-redux/
    I have also attached the .reg file for your use (Change the extention from .txt to .reg).  Good luck!
    New Member
    05-21-2012 09:35 AM in reply to: civilfx
    Thanks fixed mine too E-mail originating from AstenJohnson E-mail Services.
    New Member
    dejankocovski
    11-23-2012 02:47 PM in reply to: civilfx
    The attachment worked
    (I never download random file but I was desperate and it worked out in the end)
