• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Accepted Solution
    Load Family
    207 Views, 4 Replies
    09-17-2012 07:55 AM
    I have installed Revit 2013 but I don't have the default project template loaded (I don't know why...).
    I decide to make my own project template and for doing it the first step is to load the necessaries families but I don't know how to load all families in one time (for example all the australian libraries).
    Is there a way to do it?
    Please use plain text.
    *Expert Elite*
    Re: Load Family
    09-19-2012 05:46 AM in reply to: Symo90
    There are add-ins such as the Family Loaded Pro that can do this.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Re: Load Family
    09-19-2012 07:59 AM in reply to: Symo90
    Thank You very much! :smileyhappy:
    Re: Load Family
    09-19-2012 08:05 AM in reply to: Symo90
    But is a payment software... T.T
    *Expert Elite*
    Re: Load Family
    09-19-2012 08:12 AM in reply to: Symo90
    I'm sure that there are other programs out there then, but I don't know of any (I don't use them).
    An alternate method, if it helps, is to create Shortcuts to all of your Families (Explorer » select all » right-click » 'Create Shortcut') and then move all of the shortcuts into a single folder. Revit can load in these families by selecting the Shortcuts, and you can load in all of the Families (via the Shortcuts) within a single folder pretty easily.
