• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    alberto2013
    Linked Cad Drawing (EDIT)
    309 Views, 2 Replies
    07-11-2011 03:44 PM
    question:
    I am trying to find out if there is a quick launch for editing a linked cad file in autocad?
    for example:  I have a linked cad plan on a sheet in revit and would like to edit some layers, is there anyway to select the cad in revit and have it launch autocad and open that file?
    or do you have to manually open the file from it's folder path, save, and reload?
    thanks
    also i am primarily using 2009, sometimes 2011
    Please use plain text.
    Employee
    Re: Linked Cad Drawing (EDIT)
    07-12-2011 06:11 AM in reply to: alberto2013
    Unfortunately there is no method to launch a CAD link and edit the CAD file in AutoCAD.
    You can select the CAD link in Revit > Delete Layers, should you wish to remove specific layers from all project views.
    Thank you,
    Ryan Duell
    Revit Clinic
    @revitclinic
    New Member
    jojo-yce
    08-22-2011 07:54 AM in reply to: ryan.duell
    So it is not possible to link a CAD file to another CAD file? ..
    Because I have a map with buildings and I want every building has a link...
    Thanks!
