• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    shawn
    Line weigths different in different view.
    75 Views, 1 Replies
    02-08-2012 10:35 AM
    Greetings,
    I have just adjusted line weights for a project while in a section view - using "visibility/graphics" and object styles- and it all went pretty well. Line weights seem to have adjusted in all views.... except one. I still have one section view where the line weights didn't seem to have adjusted. I closed the project and reopened it thinking that may be needed, but it didn't help. I still have one view with very heavy lines.
    Does anyone know what setting or variable may be causing this?
    On another note, I have adjusted ALL my line weights using only pens 1,2, or 3.. and the cut lines still look heavey on cut sections, compared to what I'm used to with AutoCad. Do any of you find that you have to go and change the actual lines weights themselve vs. just changing the "pen" number to get a traditional pen 1-5 line weight?
    Thank you.
    SG
    shawn
    Re: Line weigths different in different view.
    02-08-2012 11:51 AM in reply to: shawn
    Never mind!
    Apparently I had applied some "overrides" to this particular view earlier and had forgotten. :smileyembarrassed:
