• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    ics
    Member
    Licensing System Error 30: Failed to start Adlm for revit 2012
    395 Views, 3 Replies
    01-31-2013 09:24 AM
    Im having issues with opening Revit Arch 2012. Every time I start revit I get this message "Licensing System Error 30: Failed to start Adlm" along with a bunch others stating that The software will only be able to read files and not save. The software was working just fine a few days ago and was installed months ago. I have read several post that are similar to The problem I am having. One post suggested uninstalling The software, which was my next step but for some reason The uninstall process failed. Very frustrating. We are running windows 7 64 bit and revit 2012 architecture is our software.
    Another thing, when I try to install Architecture Desktop, it wont install at all.
    any help would be appreciated.
    Thank you
    Please use plain text.
    philip.s
    Re: Licensing System Error 30: Failed to start Adlm for revit 2012
    01-31-2013 12:46 PM in reply to: ics
    Hello ics,
    You might want to try utilizing Microsoft Fix-it for your uninstall issue.
    In regards to the Architectural Desktop install failure, I'd recommend creating a new thread / attaching your install log for additional troubleshooting. Is that going on the Windows 7 machine as well? If so you might want to have a look at this Windows 7 Compatibility page.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    ics
    Member
    02-04-2013 07:34 AM in reply to: ics
    Our autodesk dealer resolved our issue by remoting into the computer and running some software that fixed the problem. They had to basically completely remove anything related to revit or autocad. This goes for anything in the registry. Once that was finished, they ran Mircosofts fixit tool just to make sure there are no other problems. The software was loaded and ran with no problems.
    the dealer used a software called Revo Unistaller Pro. Works great!
    philip.s
    02-04-2013 12:07 PM in reply to: ics
    Thanks for following up / anyone that finds them selves in a similar situation should explore the options of utilizing one of the following tools (including Revo) linked here.
    Philip Schmelzer
    TW | PI | YT | BLOG
