Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Levels not showing up in the East Elevation View
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1477 Views, 3 Replies
02-10-2010 09:55 AM
I have two levels that are shown in ELevation views North, South and West. The East Elevation view has levels showing but two are missing. How do I get these levels to show up?
Maurey
Maurey
Re: Levels not showing up in the East Elevation View
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-11-2010 09:43 AM in reply to:
mverzier
A couple of things to try;
1) ZE to see if the level head is just off the screen. See if you have somehow dragged then end off the screen. I have done this before......
2) have you checked to see if they are hidden in that view? I have done this also.....
Wiley
Wiley
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-11-2010 06:07 PM in reply to:
mverzier
Sometimes this happens when the 3D extents of the level don't intersect the viewing plane of the elevation (or whatever view the level happens to not be showing up in).
You've got a couple of options here (and maybe some more that I don't know about).
First, I'd try extending the view range of the elevation. Go to a plan view, select the callout of the elevation, and drag the extents window out until it crosses the extents of the level. This is kind of hit or miss, since you don't always know the 3D extents of the level, but if the view range crosses one of the elevations where the levels do show up, then it's a good bet that they'll show up in your other elevation as well.
If that doesn't work, go to a view where you can see the missing levels, select one, right-click, and choose 'reset 3D extents' (my wording may be off, but you should be able to figure out which one is the right one). You'll have to do this for each of the 'missing' levels. Unfortunately, this often has the unintended consequence of resetting the level marker in every view where those levels show up, but it almost always works.
If neither of those options works, then you've got me stumped. I guess you could always post the file and ask for an expert's opinion.
Good luck.
Good luck.
Ross Kirby
BIM Manager
Arcturis
BIM Manager
Arcturis
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-14-2012 06:36 PM in reply to:
rosskirby
also check that the level isn't associated with a scope box, which can limit the 3D extents of the level.
