• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Member
    JustBrev
    Accepted Solution
    Label Contours
    155 Views, 2 Replies
    06-08-2012 11:18 AM
    I have two project files; one is the topography/site and its titled (site.rvt) , the other is the building and is titled (building.rvt).
    In order to complete the architectural document set I have linked (site.rvt) into (building.rvt). this allows for completion of the site plan and other civil details. Note: The civil/site work is not sufficient to necessitate a civil drawing set.
    My question: how can i label the contours of the linked file?
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Label Contours
    06-08-2012 11:30 AM in reply to: JustBrev
    The site needs to be tagged in Site.rvt, in the Site view. Then, in Building.rvt, in your Site view, after inserting Site.rvt a a link, go to Visibility Graphics > Revit links > Display settings > By host view > Custom > "By linked view" > Site. That will bring the settings of the Site view from the linked file, into the Site view of the host file, showing the tags.
    Planta1 Revit Online Consulting | info@planta1.com
    Member
    JustBrev
    Re: Label Contours
    06-08-2012 11:55 AM in reply to: Alfredo_Medina
    Perfect, Thankyou
