• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    Jamping Jack Flash
    121 Views, 3 Replies
    12-03-2012 09:01 AM
    Yesterday morning I discovered that when I clicked on a wall. text or anything that element would jump up on the screen.
    Has anyone experienced this?
    David
    Please use plain text.
    New Member
    daithio3
    Re: Jamping Jack Flash
    12-04-2012 10:10 AM in reply to: DavidRaines
    David,
    Ive noticed this on on ocasion when the extents of your model has be exceeded. error.JPG
    Check that your not getting this error, and also that your Project base point isnt too far away from the centre of your project.
    Product Support
    fernanda.firman
    12-05-2012 10:36 AM in reply to: DavidRaines
    Hi David,
    This type of issue is usualy realted to graphic cards.
    Here are some things to try:
    1. Update your graphic card
    http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
    2. Make sure you have the latest update for Revit
    3. Turn off Hardware Accelaration - Go to the big "R" on the top left>Options>Graphics
    4. Use Revit on the primary monitor , if you are using dual monitor.
    Hope that helps!
    Fernanda Lima Firman
    Revit Support Specialist
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    Active Contributor
    12-05-2012 11:34 AM in reply to: DavidRaines
    The easy fix for this issue is to un-tick the press and drag tick box down the very bottom right of the application screen. You will still get a flicker but the selected objects will not move. After un-ticking this box when you want to drag something you need to click to select then click and drag.
    _________________________________________________________________
    KarelCAD Application Support Specialist
