• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Re: Italian language pack for Revit 2013
    12-03-2012 05:24 AM in reply to: tony.michniewicz
    Hi
    I did what you wrote. I also changed Revit.ini file to set proper language but nothing happened. What is funny:
    "DefaultTemplate=Stavební šablona=C:\ProgramData\Autodesk\RVT 2013\Templates\France\Construction-DefaultFRAFRA.rte" ... this is a default path for Czech Template... France.
    Gooood jooob.
    Can somebody tell me if it realy works and what shoud I do to make it happen?
    Thank you
    Rudolf
    Please use plain text.
    Active Contributor
    12-03-2012 05:25 AM in reply to: yaoqiangjian
    you should download proper language pack from subscription center, not from autodesk webpage. And check if it is for suite or architecture/structure/mep only.
    Rudolf
    New Member
    kuba74
    01-27-2013 02:16 AM in reply to: tony.michniewicz
    Hi!
    I've this same problem with polish language pack for Building Designs, I install with your instruction but that still dont work!
    Employee
    01-29-2013 06:20 AM in reply to: rudolf.vyhnalek
    Could you provide more details regarding your problem installing the Polish language pack?  Is there an error message and when do you see the error message; during the install setup, at the end of the installation process or when attmepting to launch the product?  Hopefully with a bit more information, we can get the language pack installed and running on your system.
    Tony Michniewicz
    Autodesk Revit QA
