• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    andrea.pontiggia
    Italian language pack for Revit 2013
    5078 Views, 23 Replies
    05-10-2012 03:49 AM
    Hello, can you tell me when it's ready for the Italian language pack inserted in the version of Revit Building Design Suite Premium 2013? thanks
    Andrea
    Please use plain text.
    Product Support
    Re: Italian language pack for Revit 2013
    05-15-2012 09:49 AM in reply to: andrea.pontiggia
    Dear andrea.pontiggia
    You can find the language packs for Revit 2013 from the links below:
    Revit Architecture 2013
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=19222370&linkID=19222558
    Revit MEP 2013
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=19222482&linkID=19223913
    Revit Structure 2013
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=19222489&linkID=19223921
    Please let me know if you need further assistance.
    Best regards,
    John Lipp
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    06-13-2012 04:14 AM in reply to: john.lipp
    It's possible using other product languages as you tell?
    please any workaround or how-to about this?
    I intereresed in spanish translation but no have idea ho do this with languages packages of simple Revit architectural or Revit MEP
    Thans and best regard
    Yulian
    New Member
    06-16-2012 02:48 AM in reply to: spatialy
    I'm trying to install the italian language pack for revit 2013 but I'm experincing the following issue: once I click over the EXE file (Autodesk_Revit_2013_Italian_LP_Win_32-64bit.exe) the unpack application shows me only "extract" (not "install"). After having uncompressed all the stuff, if I go into the unpacked dir I don't find any way to install the italian language pack (there is only setup.ini and not setup.exe).
    As to other language packs I don't have the same issue (the EXE file shows me the "INSTALL" button).
    How should I fix it?
    andrea.pontiggia
    06-27-2012 04:28 AM in reply to: paolo
    I have the same problem Paolo.
    What should I do to the language pack ita Revit 2013 included in Buiklding Design Suite?
    Tanks Andrea
    Andrea
    Member
    09-23-2012 03:07 PM in reply to: andrea.pontiggia
    Hi I have the same problem, I don,t know how to install the language pack,
    Member
    09-23-2012 03:08 PM in reply to: paolo
    Hi, have you fixed the language pack problem? cause i have the same problem.....
    andrea.pontiggia
    09-24-2012 12:21 AM in reply to: yaoqiangjian
    I did the following:
    -I installed the suite without Revit 2013;
    -I downloaded from the site Autodesk Revit-ita;
    -I installed Revit 2013 with serial suite.
    Andrea
    Employee
    09-25-2012 10:18 AM in reply to: andrea.pontiggia
    Revit handles language packs differently than AutoCAD and they must be included as part of the initial installation.  Here are the steps to include a language pack in a Revit installation.
    1. Download and extract the contents of the desired language pack.
    2. Launch the Revit installer and accept the end user license agreement, which will bring you to the Product Information page.
    3. Expand the Product Language drop-down list and select Add Language Pack.
    4. In the resulting dialog, click the Browse button associated with the Revit product being installed.
    5. Navigate to and select the appropriate MSI file from the extracted language pack content, then click Open.  As an example, here is the path to the MSI file for the French language pack for Revit Architecture on a 64-bit system: C:\Autodesk\Autodesk_Revit_Architecture_2013_French_LP_Win_32-64bit\x64\fr-FR\RAC2013\RAC2013LP.msi.
    6. Click OK to dismiss this dialog.
    7. Complete the remainder of the Revit installation.
    Once the installation is complete, Revit will be configured using the selected language pack.
    Tony Michniewicz
    Autodesk Revit QA
    Member
    09-25-2012 03:08 PM in reply to: tony.michniewicz
    Hi, thanks for the reply, but it doesn't work. here pic. I downloaded the language pack Autodesk.REVIT 2013.jpg
