• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Accepted Solution
    Issues concerning the “schedule”,
    150 Views, 2 Replies
    11-06-2012 12:40 PM
    • How to control the width of column and the height of row?
    • How to choose the size, color and type of font?
    • How to have the unit of each column in the head row?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    *Expert Elite*
    Re: Issues concerning the “schedule”,
    11-06-2012 01:25 PM in reply to: JamaL9722060
    JamaL9722060 wrote:
    "How to control the width of column and the height of row?"
    You can control the width of the columns by selecting the Schedule Graphic and dragging the triangular grips that appear. This is in no way associated to the width of the column in the Schedule View. See image below. The height of the rows, however, cannot be manually controlled. That's based purely on the number of lines of text in the lines of data.
    JamaL9722060 wrote:
    "How to choose the size, color and type of font?"
    You can control the size and type of font of the Schedule Graphics under the Appearance tab in Schedule View's Properties. Color is not an option. You cannot control the appearance of the font in the Schedule View. See image.
    JamaL9722060 wrote:
    "How to have the unit of each column in the head row?"
    Revit cannot automatically add the unit to the header. You will have to manually add any such text by going to the Format tab under the Schedule View's Properties. See image.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    11-07-2012 02:22 PM in reply to: CADastrophe
    Many thanks for the answer and the fantastic screenshots
    This is quite helpful
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
