• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    mudkipz223
    Is a Geodesic Dome feasible?
    276 Views, 3 Replies
    02-06-2012 09:24 PM
    Hello, I was planning on doing a geodesic dome-home design in one of my architecture classes and I was wondering if anyone had any ideas on how to go about it. I have the dimensions of the house and the sizes of each triangular "panel" of the house; however, I'm not sure of how to construct it within revit. Would it even be worth the effort? Or is there another way, possibly through Autocad, if order to construct a geodesic dome easier?
    Distinguished Mentor
    Re: Is a Geodesic Dome feasible?
    02-07-2012 05:53 AM in reply to: mudkipz223
    It is possible in Revit, using a Conceptual Mass, thena Divided Surface, and a Pattern Based Curtain Panel applied
    to the Divided Surface.
    Do a search on these topics.
    cheers
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Employee
    loboarch
    02-07-2012 08:34 AM in reply to: mudkipz223
    Cliff got to the question be fore I did, but the conceptual massing tools will probably be able to get waht you are after.  Here is an example I created in about 5 minutes.  It is not exactly a geodesic dome in the fact all the panels are different sizes.  with a bit more math applied and some more time taken I think it could get there.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    02-07-2012 08:43 AM in reply to: loboarch
    Also take a look here:
    http://wikihelp.autodesk.com/Vasari/enu/Community/Tutorials/Vasari_Talk_-_Design_and_Analysis_Webina...
    Zak shows how to use reporting parameters to check if the panels are "flat" and to report lengths of each "leg"
    of the panels. His demo is not on a pure dome shape, but a similar approach could be applied to the geodesic dome.
    cheers
    Cliff B. Collins
    St. Louis, MO
