• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Re: Imported 3d DWG Model, Section not working
    11-08-2004 06:32 AM in reply to: Mitchel Stangl
    So I can do this with a link, so that I can update the sketchup file and get it to update in Revit, like a XREF?
    Please use plain text.
    *DH
    11-12-2004 09:28 AM in reply to: Mitchel Stangl
    > generate elevations. You can also now pick linework within & snap to > this imported model to generate a 'real' building within Revit... No Revit export filter for SketchUp, like there is for ADT?
    *Jeffrey McGrew
    11-17-2004 10:19 AM in reply to: Mitchel Stangl
    DH wrote: >>generate elevations. You can also now pick linework within & snap to >>this imported model to generate a 'real' building within Revit... > > No Revit export filter for SketchUp, like there is for ADT? Do you mean can you export your Revit models to Sketchup? Because you can do that just by exporting a DXF out of Revit & bringing it into Sketchup. If you mean is there a tool that allow you to pull in a Sketchup model into Revit, then yes, you can import a Sketchup model into Revit. if you mean is there a tool that lets you then select things within the sketchup model and have them become your chosen Revit elements, then yes, you can do that too. But if you mean is there a tool that takes a Sketchup model and makes it a Revit Building automatically without intervention, then no, there isn't that. Jeffrey
