Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
I would like to create a second drawing without the exterior wall finish layer
- Highlight
- Email to a Friend
I am looking for a method to realize 2 different drawings in the same revit file.
In fact, I made a drawing with all the layers of the wall included exterior finish layer.
Now I would like to create a second drawing without the exterior wall finish layer (stucco thickness 1 cm).
I hope you understand my request, because it is not easy to translate it (French to English).
The mason wants a drawing without finishing outside of the walls.
I think there must be a solution, but I do not see how.
Thank you for your help.
Re: I would like to create a second drawing without the exterior wall finish lay
- Highlight
- Email to a Friend
I think you need to delete the finish layer from the compound wall type, and create another wall type just for finishes. Then, you can show or hide that finish wall as necessary.
Planta1 Revit Online Consulting | info@planta1.com
- Highlight
- Email to a Friend
carpentier_guillaume wrote:
"I hope you understand my request, because it is not easy to translate it (French to English)."
The translation is flawless and the expression of ideas is perfect.
- Highlight
- Email to a Friend
Thank you to try to help me.
I find this solution is not the best.
I really want to have 2 different drawings.
Thank you.
- Highlight
- Email to a Friend
carpentier_guillaume wrote:Hello,
Thank you.
Then, do 2 different models. I thought you wanted a method to avoid having to model twice.
- Highlight
- Email to a Friend
Yes, I want only one REVIT file, with 2 drawings.
- Highlight
- Email to a Friend
As I said above, the finish layers need to be modeled separetely, with their own wall type, which can be shown or hidden, using filters. The reason is because there is no way to hide just the finish layer when it is part of a wall type with multiple layers.
- Highlight
- Email to a Friend
There is a way to do this in a single Revit file, but you need to convert your walls to 'parts' and for this you must be using Revit 2012 or later version.
After converting your walls to parts, you can use view filters to hide the finish layers in a drawing. You'll find more about this by serching the 'parts' and 'filters' section of online Revit help.
Though this is a way to do what you want to do, I'm not really a supporter of converting huge number of elements to 'parts'. It creates more problems than solutions as per my opinion.
Hope this helps.
- Highlight
- Email to a Friend
Dear RakasaPlus,
It is a lengthy process (and may have some drawback as well) but you can achieve desired result.
You need to follow these steps.
- determine what is your level to level height (let's say 10''-0")
- Now create a new family (using Profile template) and draw a profile with the width of wall finish layer which you want to hide (for example 2") and the height of that profile would be 10''0" (height of your walls).
- Save that profile family with a defined name.
- Now in your project, you can draw walls without exterior finish (which you want to hide in one drawing). Only the wall structure with appropriate thickness.
- Now go to 3d view, Choose Wall Sweep option form Wall drop down menu.
- Select the desired wall (all exterior) and place that wall sweep.
- Now half of your job is done.
- Go to floor plan, duplicate it (preferably 'with detailing') and rename it as desired.
- Now in the floorplan where you want to hide the exterior finish, go to visibility graphics option, Click on the + (Plus) symbos before the Walls, uncheck the 'Wall Sweeps - Cornice' option.
- You are done.
Let us know if you face any difficulty in any of these steps and also your feedback if this resolves your query or not.
