• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    I would like to create a second drawing without the exterior wall finish layer
    185 Views, 8 Replies
    05-01-2012 02:06 PM
    I am looking for a method to realize 2 different drawings in the same revit file.
    In fact, I made a drawing with all the layers of the wall included exterior finish layer.
    Now I would like to create a second drawing without the exterior wall finish layer (stucco thickness 1 cm).
    I hope you understand my request, because it is not easy to translate it (French to English).
    The mason wants a drawing without finishing outside of the walls.
    I think there must be a solution, but I do not see how.
    Thank you for your help.
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: I would like to create a second drawing without the exterior wall finish lay
    05-01-2012 02:22 PM in reply to: carpentier_guillaume
    I think you need to delete the finish layer from the compound wall type, and create another wall type just for finishes. Then, you can show or hide that finish wall as necessary.
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Mentor
    vector2
    05-01-2012 05:11 PM in reply to: carpentier_guillaume
    carpentier_guillaume wrote:
    "I hope you understand my request, because it is not easy to translate it (French to English)."
    The translation is flawless and the expression of ideas is perfect.
    Member
    05-02-2012 01:55 AM in reply to: Alfredo_Medina
    Thank you to try to help me.
    I find this solution is not the best.
    I really want to have 2 different drawings.
    Thank you.
    *Expert Elite*
    Alfredo_Medina
    05-02-2012 03:23 AM in reply to: carpentier_guillaume
    Thank you.
    Then, do 2 different models. I thought you wanted a method to avoid having to model twice.
    Member
    05-02-2012 05:03 AM in reply to: Alfredo_Medina
    Yes, I want only one REVIT file, with 2 drawings.
    *Expert Elite*
    Alfredo_Medina
    05-02-2012 07:18 AM in reply to: carpentier_guillaume
    As I said above, the finish layers need to be modeled separetely, with their own wall type, which can be shown or hidden, using filters. The reason is because there is no way to hide just the finish layer when it is part of a wall type with multiple layers.
    Active Contributor
    sagar.londonites
    05-02-2012 08:40 PM in reply to: carpentier_guillaume
    There is a way to do this in a single Revit file, but you need to convert your walls to 'parts' and for this you must be using Revit 2012 or later version.
    After converting your walls to parts, you can use view filters to hide the finish layers in a drawing. You'll find more about this by serching the 'parts' and 'filters' section of online Revit help.
    Though this is  a way to do what you want to do, I'm not really a supporter of converting huge number of elements to 'parts'. It creates more problems than solutions as per my opinion.
    Hope this helps.
    - Sagar
    parveen.revit
    05-02-2012 10:18 PM in reply to: carpentier_guillaume
    Dear RakasaPlus,
    It is a lengthy process (and may have some drawback as well) but you can achieve desired result.
    You need to follow these steps.
    • determine what is your level to level height (let's say 10''-0")
    • Now create a new family (using Profile template) and draw a profile with the width of wall finish layer which you want to hide (for example 2") and the height of that profile would be 10''0" (height of your walls).
    • Save that profile family with a defined name.
    • Now in your project, you can draw walls without exterior finish (which you want to hide in one drawing). Only the wall structure with appropriate thickness.
    • Now go to 3d view, Choose Wall Sweep option form Wall drop down menu.
    • Select the desired wall (all exterior) and place that wall sweep.
    • Now half of your job is done.
    • Go to floor plan, duplicate it (preferably 'with detailing') and rename it as desired.
    • Now in the floorplan where you want to hide the exterior finish, go to visibility graphics option, Click on the + (Plus) symbos before the Walls, uncheck the 'Wall Sweeps - Cornice' option.
    • You are done.
    Let us know if you face any difficulty in any of these steps and also your feedback if this resolves your query or not.
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
