• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Accepted Solution
    How to switch the order of the layers of a wall without changing the dimension,
    249 Views, 5 Replies
    10-01-2012 01:47 PM
    In the screenshot below, I wanted to switch the order of the layer without changing the dimension. Is that possible?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    *Expert Elite*
    LisaDrago
    Re: How to switch the order of the layers of a wall without changing the dimensi
    10-04-2012 04:42 AM in reply to: JamaL9722060
    This depends on the location line (Origin) of the wall as you place it. My Guess the location line is not on the wall center line - maybe the core center line which will give it a bit of an offset.
    I have added an image below... when you select the wall in the properties - where is the location line (Origin) of the wall?
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    JamaL9722060
    10-05-2012 02:05 AM in reply to: LisaDrago
    Thank for the answer.
    Correct. It is drawn with “Finish Face: Exterior” for the “location line”.
    But in this case, how to switch the “location line” to be “Wall centerline”?
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    LisaDrago
    10-05-2012 05:00 AM in reply to: JamaL9722060
    The wall you have selected - in the properties dialog box - you can change the location line... i
    JamaL9722060
    10-05-2012 08:09 AM in reply to: LisaDrago
    Many thanks of the answer. This is very useful. I like your screenshots. My issue is resolved. Sounds to take us a while to get used to the Revit.
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    LisaDrago
    10-05-2012 08:14 AM in reply to: JamaL9722060
    Yes - screen shots are very useful and I was able to your yours to make it a bit easier.
    Revit is not a program to just pick up and yes - there are a lot of little intricate things to work out to make things work the best.
    ALso if a solution has been given - can you mark it 'accepted' - only you can do this for the questions you ask. It makes it easier for other to quickly find answers that have worked.
    Have a great day!
    LD
