• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    How to set the distance between the views?
    167 Views, 4 Replies
    09-15-2012 01:46 AM
    Is there a way to set the distance between the views? How much is it by default?
    Bets
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Employee
    Re: How to set the distance between the views?
    09-15-2012 08:33 AM in reply to: JamaL9722060
    There is  no need to set the distance between these tags.  They can be moved any where you like.  If you click on just the "arrow" part of the tag, a line that represents where the elevation view is being "cut" from will be exposed.  You can adjust the position and the length of this line as needed.
    Scott D Davis
    AEC Technical Specialist
    North American Sales
    Autodesk, Inc.
    Want Revit Content? Go to http://seek.autodesk.com !
    JamaL9722060
    09-15-2012 01:32 PM in reply to: davissc
    thank you for the help.
    how to reset the default settings of the line?
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    Employee
    09-16-2012 04:11 PM in reply to: JamaL9722060
    Make the template file appear the way you like, and re-save it as a template.  Use that template to start a project, and it will always be the way you set it up to be.
    Part of your implementation of Revit should be to create your own template file.  the out of the box templates are meant as a basic starting point.
    Training is definitely a must as well.
    Scott D Davis
    Autodesk, Inc.
    JamaL9722060
    09-17-2012 12:44 PM in reply to: davissc
    Many thanks for the prompt answers Scott.
    I feel that my question is still not answered. Just I wanted to know about the default distance between these tags and the way we reset them to their default mode.
    Is there any philosophy beyond the default distance between the tags. My question might seem very minor just I wanted to know
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
